belt size
Old May 4, 2013 | 04:14 PM
Chet1185's Avatar
belt size
Engine is ready to be fired for the first time. I bought a used AC delete pulley and he gave me a new belt with it. That belt is to small and mine is to big.
Mine I can slide right off after its on, the new one I can get about halfway on the balancer.
What can I do.....
Posted from Camaroz28.com App for Android
Old May 4, 2013 | 04:18 PM
Chet1185's Avatar
Mine is a 643k6, the one I got with the pulley is a 620k6
Old May 4, 2013 | 06:06 PM
slick1hunting's Avatar
take both to the parts house and find one in between.
Old May 4, 2013 | 06:07 PM
double check you are routing correct too.
Old May 4, 2013 | 06:18 PM
Chet1185's Avatar
Just got a 630k6, its routed right.
Old May 4, 2013 | 11:49 PM
Re: belt size
GM used two different pulley sizes for the a/c. So, depending on which one you originally had, the belt may or may not be the same as before. 642 and 635 belts were used.
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Aug 20, 2015 03:40 PM
Dams76
Aug 20, 2015 08:28 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
