belt pulley??
Old Jan 7, 2004 | 03:30 PM
BigTed187's Avatar
belt pulley??
I have a 95 z28 and i have a problem....i cant seem to pull the pulley off to do an opti change. but im having some problems getting it off. i got three bolts loosened and yet it doesnt seem to come over very easily?? any ideas?? thanx
Old Jan 7, 2004 | 03:44 PM
ibanez6rg's Avatar
There's a belt tensioner between the A/C compressor and crank pulley.
Look on top of your radiator for directions.
Old Jan 7, 2004 | 03:55 PM
m_morrison14's Avatar
go to autozone and rent the puller with 3 arms with hooks on them. I had the same problem, with the puller it came right off with a few twists.
Old Jan 7, 2004 | 03:58 PM
ibanez6rg's Avatar
Man, I need to get some sleep... I completely read it thinking you were trying to get you serpentine belt off.
Yea, you'll need a wheel puller to get that off, if you want to make it easy.
Old Jan 7, 2004 | 04:11 PM
If it won't come off by other means, use a puller.
Old Jan 7, 2004 | 04:18 PM
speedracer93z28's Avatar
i just kept tugging at mine until it came off, but if that doesnt work get a 3-jaw puller.
Old Jan 7, 2004 | 07:56 PM
ibanez6rg's Avatar
What do you use to get the piece off the crank that holds the harmonic balancer?
Old Jan 7, 2004 | 08:24 PM
BigTed187's Avatar
Harmonic balanceR?? can you explain to me where that is located, cuz all i did was take a 5/8 socket to pull of all three bolts, but there's a bolt in the middle?? do i take that one off to or just leave that on soo the engine doesnt spin freely??
Old Jan 7, 2004 | 08:36 PM
ibanez6rg's Avatar
You've already taken off the harmonic balancer (crank pulley). The bolt in the center holds that piece to the crank, which holds the harmonic balancer. You don't need to take it off for an opti change.
Old Jan 7, 2004 | 08:38 PM
If you looked at my link above, it says to put a socket over the crank bolt, so yeah, you leave it in (it won't keep anything from spinning, though). All you need to do is remove the pulley to replace the opti.
ibanez6rg: to remove the hub, you use a conventional (crow foot) balancer puller.
RUENUF
Mar 13, 2016 03:37 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
