Belt keeps getting chewed up
Old Apr 23, 2003 | 09:22 AM
lovemy6spd's Avatar
Unhappy Belt keeps getting chewed up
I have replaced my belt couple of times. Keeps getting chewed. I had a friend look at it and said the AC pully looks to be chewing it up. He said to get a AC Clutch/Pully does that make since? Can I replace just those parts? Thanks.
Old Apr 23, 2003 | 09:27 AM
LOW TRAC's Avatar
Seems kinda strange that just the pully is bad, usually that means the bearings are going bad and the pully wobbles. Unless the pully looks like it has a dent in the groves or has been wacked resulting in it being unballanced, I'd have someone take a closer look.
Old Apr 23, 2003 | 09:44 AM
Dave 96TA's Avatar
I'm having the same trouble, see my post just this morning http://web.camaross.com/forums/showt...hreadid=111021
Having a problem with my A/C unit too...maybe thats the answer. I have a replacement sitting in a box, but no time to install it yet.
Old Apr 23, 2003 | 11:01 AM
shox9879's Avatar
belts
check your tencher pully those wear out and get miss alined and will make your belt feed to the next pully funny an the groves will tear yp ypur belt
Old Apr 23, 2003 | 01:20 PM
Pulley alignment or a bad pulley would be the most common problems resulting in belt destruction.
Old Apr 23, 2003 | 01:51 PM
FireAm94's Avatar
Do you have an underdrive crank pulley?
Joe
Old Apr 23, 2003 | 05:27 PM
lovemy6spd's Avatar
Joe
All my pullys are stock.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
