bellhousing removal
bellhousing removal
I can't get this last bolt of the bellhousing...I'm putting in a new clutch...the bolt is so close to the inside of the tunnel i can't get a socket or a wrench on it. Is there anyway to twist the motor to the side a little to get at this bolt?
no. i tried a swivel socket. it just twists over the bolt. Its getting rounded which doesn't help. I even tried taking the passenger side motor mount out to lower the motor a bit but no luck. I'm thinking my only chance is to get at it strait on with a regular socket.Is there a way to lower the k-member a bit so i can twist the motor over so i can get at this thing?
The bolt you are having trouble with this on dr. side I always drop the engine and trans down a couple of inches to get that bolt out. make a mark with a magic marker and when you take bell housing off make a small dent with a hammer so you can get to it next time. Good Luck!
Sounds like that would work also but at a certain point the brake lines will have to be undone I have ever drop the k member down. I always pull motor out the top .but it sounds like it would work!
No need to drop the entire engine. Take your temporary support out from under the back of the engine/tranny. Push up on the damper, and the back of the engine will tilt down far enough to give you access to the bolt.
You can also pry the sheet metal around the bolt up to get better access. That and a swivel socket and your golden.
Yeah, what he did. Took, I think, 2 ft or more of extensions but it worked. Never saw that much of an extension before I did it myself.
