beginning mods...what areas to target??
Old Sep 8, 2005 | 01:30 PM
The35thZ's Avatar
im lookin to start moddin the car soon. its a 97 30th ann. z28 bone stock. i already have the cai/headers/exhaust in mind. that takes care of the airflow. any other areas of the car that are weak and easily upgraded?? ignition, fuel, handling, etc....????
Old Sep 8, 2005 | 01:38 PM
Purplemaroz28's Avatar
Re: beginning mods...what areas to target??
if you're going to do those mods then i would suggest a lt4 knock module and a pcm tune from madz28 or pcmforless. as far as suspenison goes... subframe connectors, panhard rods, and lower control arms all help. is it a m6 or auto?... gears could be a consideration for either.
Old Sep 8, 2005 | 01:50 PM
Z06Z28's Avatar
Update your sig to show if that 97 is an auto or manual.
I recommend:
cai, headers with lt4 km, catback, 160 stat with pcm tune.
For my A4 96 Z..I loved the firm shifts and throttle response was great.
Also recommended:
better tires, good shocks, sfc's, replace wornout bushings with poly bushings everywhere, better brake pads and stainless steel lines.
Consider:
gears, stall or clutch with rear-end prep
Old Sep 8, 2005 | 03:59 PM
Z95m6's Avatar
I'd also recommend SFC's, and either a stall if you have an auto, or a shifter if you have a manual.
Old Sep 8, 2005 | 04:12 PM
2000GTP's Avatar
As of right now, your stock fuel/ignition systems will be up to par to handle small bolt-ons, but if you ever go the forced induction route or build a heads/cam motor, then it is time to start looking into that stuff. Otherwise, if it hasn't already been addressed, do a good plug, wires, and fuel filter change.
Old Sep 8, 2005 | 04:19 PM
Jps 1LE's Avatar
I would definitely recommend a set of gears, stall, and some drag radials to get ya started. Also i agree with everyone else with the suspension parts. Either way you can't go wrong.
football4life
Oct 4, 2015 07:48 AM
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
navtool.com
Middle Atlantic
Sep 24, 2015 03:17 PM
Sep 11, 2015 09:44 AM
