beginning mods...what areas to target??
im lookin to start moddin the car soon. its a 97 30th ann. z28 bone stock. i already have the cai/headers/exhaust in mind. that takes care of the airflow. any other areas of the car that are weak and easily upgraded?? ignition, fuel, handling, etc....????
Re: beginning mods...what areas to target??
if you're going to do those mods then i would suggest a lt4 knock module and a pcm tune from madz28 or pcmforless. as far as suspenison goes... subframe connectors, panhard rods, and lower control arms all help. is it a m6 or auto?... gears could be a consideration for either.
Update your sig to show if that 97 is an auto or manual.
I recommend: cai, headers with lt4 km, catback, 160 stat with pcm tune. For my A4 96 Z..I loved the firm shifts and throttle response was great. Also recommended: better tires, good shocks, sfc's, replace wornout bushings with poly bushings everywhere, better brake pads and stainless steel lines. Consider: gears, stall or clutch with rear-end prep |
I'd also recommend SFC's, and either a stall if you have an auto, or a shifter if you have a manual.
I would definitely recommend a set of gears, stall, and some drag radials to get ya started. Also i agree with everyone else with the suspension parts. Either way you can't go wrong.
