Before you go and replace your MAP
Old Jun 27, 2003 | 04:44 PM
TobyZ28's Avatar
In response to some people checking out the threads on the miracle map replacement fix.. try taking the existing one off first and checking to make sure the rubber gasket is sealing it properly.. I just pulled mine out and the rubber gasket was kinda "squished" on one side and might have been leaking a slight amount of air.. which would throw your map off... just a suggestion before you decide go and replace it
I also squirted some electronic cleaner on and in it.. *shrug* who knows if its good or bad.. should be ok tho is my guess
Old Jun 27, 2003 | 05:01 PM
TobyZ28's Avatar
Re: Before you go and replace your MAP
I should add that i thought the Gasket was a goner, but after cleaning it and kinda straightening the ripples with my fingers i was able to return it to its original form.. yay!
Q: Would putting seafoam in Via the MAP sensor hole be.. "ok"?
Old Jun 27, 2003 | 07:34 PM
Mtrhds94Z's Avatar
I use the 'canister purge' solenoid hose fitting...[for seafoam]
Old Jun 27, 2003 | 07:36 PM
Terran2k's Avatar
yeah, the little gasket on mine was squished on one side as well. I wonder if my new gasket is the same, i suppose i could take it off and look at it..
Old Jun 27, 2003 | 08:10 PM
Mikey97Z's Avatar
My gasket was squished like that too. I put sone ultra copper on it the last time I put the MAP sensor on. But I don't think it was leaking, just a precaution.
HectorM52
Jul 30, 2017 11:46 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Darth Xed
13
Aug 26, 2002 01:55 PM
