Compression test result
Old 09-28-2017, 05:35 PM
CamaroSS30thAnn's Avatar
I got 150psi on all cylinders.
355 11 to 1 comp.
236/244 598 614 if it matters.
Dry test.
Seem normal? I hear it's not about the number it's about consistency.
Also engine was cold, sat for a few days 60 degrees out. I did test one cylinder a few days ago when it was 85 degrees out it was at 180 same cylinder was 150 today but with a different tester.
CamaroSS30thAnn is offline
Old 09-28-2017, 09:22 PM
Chimera96's Avatar
Re: Compression test result
the fact they are consistent is good
Chimera96 is offline
Old 09-28-2017, 09:26 PM
figured lol
Old 09-29-2017, 06:27 PM
Originally Posted by cardo0
Compression test should be done with engine warm, nearly operating temp. But who can get their arms and hands near the exhaust manifolds on a hot engine to remove the spark plugs? And I'm sure you know you need the throttle blades fixed open.
That said good compression pressure for performance should be over 180psi but less than 220psi for pump gas. 150psi is fine for a street engine and should keep you out of detonation.
i agree. That's why I mentioned that I did a cold test.
reason being is i had no injectors at the time. Was getting them tested so I couldn't run the car.
I bet if the car was warm and lubricated it probably would have been in the 160s 170s.
I could wait to put it back together and try one or two cylinders warm. I wouldn't think id have to do all them since they would probably be the same considering my previous results.
All plugs were out and blades were open
Old 09-29-2017, 11:08 PM
In addition to the cold engine, depending on the LSA, the large cam is likely contributing to the 150 PSI result.
Injuneer is offline
Old 09-30-2017, 06:09 AM
Thank you. I was really just looking for consistency across all cylinders.
Old 10-04-2017, 05:45 PM
DrewHMS97SS's Avatar
Is it reasonable to assume that because the cylinders were all close in a cold scenario, that you would only have to test one in a hot scenario to get a reasonable idea of where the engine is? Or is heat on the rings enough of a game changer that there could be significant difference?
DrewHMS97SS is offline
Old 10-04-2017, 09:31 PM
good question
Old 10-22-2017, 12:02 PM
snorkelface's Avatar
Question Re: Compression test result
Originally Posted by CamaroSS30thAnn
good question
Any thoughts on this? I'm in the same scenario. Looking at my turbo headers, I can't see I'd be able to test any cylinders except for #1 while the car is warm without needing medical attention afterwards.
snorkelface is offline
