beehive valve springs
Old Sep 5, 2007 | 06:14 PM
93v8clone's Avatar
how many diff companies are sellin them i just bought a used set of heads to send out to loyd and they have beehive springs on them but no color band on it like mine on my car are blue down the lenght of it and these have none i cant post a pic cause i cant add attachments for some reason any help is appreciated
Old Sep 5, 2007 | 08:09 PM
seawolf06's Avatar
There are a few, but I think they all come from the same place, PRC. You can find info on them in the sponsor forum. I know PSI also has some besides CC, but I've also seen Lunati marketing them as well. You'll have to test them to figure out the specs.
Old Sep 5, 2007 | 09:14 PM
93v8clone's Avatar
they are a older set prolly 1-2 years old the guy said he knew nuttin about them his machinist put it together
Old Sep 5, 2007 | 10:21 PM
seawolf06's Avatar
Yeah, you need to test them at a shop.
Old Sep 6, 2007 | 01:06 AM
WhiteLT1z's Avatar
whats the blue band mean?
Old Sep 6, 2007 | 02:24 AM
SStrokerAce's Avatar
The blue band doesn't mean much......
Don't worry about that, have the springs all removed and have the shop check them for pressure at 1.750" height. They should all be within 140-145lbs there, if so they are most likely good.
If you need a replacement set get a hold of Lloyd or I and we can get a new set out to you for a good price.
Bret
Old Sep 6, 2007 | 06:23 PM
93v8clone's Avatar
thanks bret i need to get ahold of you guys anyway as to get a set of heads poted for my car
Old Sep 6, 2007 | 08:26 PM
2QUIK6's Avatar
The Comp ones are made in Mexico. PAC Racing was the original maker of the beehives for Comp before Comp changed to the Mexico manufacture. PAC still makes them and in the good ole USA!
Old Sep 7, 2007 | 10:02 AM
Yeahdoug's Avatar
Originally Posted by seawolf06
There are a few, but I think they all come from the same place, PRC. You can find info on them in the sponsor forum. .
PRC doesn't make springs. PRC buys them from associated spring along with Patriot, manley, and comp.
Lunati, Ferrea, and Crane buy some from us along with our own brand.
You can not go by the stripe anymore. Some of ours get a stripe and some don't.
Old Sep 7, 2007 | 11:35 AM
seawolf06's Avatar
PAC is what I meant, sorry. I wasn't sure of the manufacturer either. Thank you for clearing that up. Do you know where PSI gets theirs from?
Old Sep 7, 2007 | 12:15 PM
Yeahdoug's Avatar
PSI was started by ex-PAC guys. They make their own like us, but on a smaller scale.
R@mpage
Apr 20, 2015 10:02 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
