beehive springs
Old Mar 16, 2007 | 06:08 AM
pat35's Avatar
beehive springs
I just bought a 305 cam. a friend has a set of beehive springs on his ls1 with tie retainers. wood these fit my lt1. we don't know the part number is there only one beehive spring any help .
Old Mar 16, 2007 | 06:34 AM
ChevalierSS's Avatar
The springs will work, the retainers won't. The LS1 & LT1 have different diameter valve stem. Do a search and you can come up with the part number for the retainers.
Old Mar 16, 2007 | 06:38 AM
http://web.camaross.com/forums/showt...hive+retainers
There's the lock & retainers you will need.
Old Mar 16, 2007 | 08:06 AM
The Engineer's Avatar
It would be best to have a machine shop check and set up the installed spring height with the beehives (or any new spings). It will only cost a few bucks, but also ensures everything is set up correctly.
WD.
Old Mar 16, 2007 | 03:46 PM
seawolf06's Avatar
Are those the stock LS1 springs? I wouldn't use the stock LS1 springs on a cammed LTx motor. If they are the 918 springs, then you can use them with new locks, retainers and locators.
I also agree with The Engineer.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
