Beehive spring retainers difference between 774/787's
Old Mar 16, 2005 | 02:29 AM
vette40th's Avatar
After I purchased these retainers via Comp Cams at Jegs, I am hearing that they are different? WHat is the physical difference. I am using these in a LT1 cylinder head.
Old Mar 16, 2005 | 10:41 AM
vette40th's Avatar
Re: Beehive spring retainers difference between 774/787's
Well I couldnt figure why the retainers, 774 didnt fit my LT1, as they just seemed to big for the retainers. Well, the LT1 uses a 11/32 inch valve stem, which is .3416 inches, and the LS-1 is 8mm (.3136 inches) . So if you want to use the Comp Cams beehive valve springs you need to order the 787-16 retainers which are for the larger valve stems. Hope this helps.
Noenav
Mar 1, 2019 07:38 AM
QuickSilver02
Apr 7, 2015 11:12 AM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
