Bearing squeak problem
Old Jul 24, 2005 | 04:56 PM
llwta's Avatar
I think the bearing on my air cond. compressor clutch is going. I have a 95 T/A . It squeaks pretty loud till the engine warms up then it goes away. How much of a job is this if I take it on myself. Can I just relube the bearing somehow or do i need to buy the whole clutch ***'y. Am I looking @ a lot of work if I do it myself? Thanks a lot. Larry
Old Jul 25, 2005 | 02:47 AM
OBE1 95Z28's Avatar
Re: Bearing squeak problem
Belt squealing is a common problem, usually fixed by replacing the belt. One way to check is to buy a can of belt dressing; spray a small amount onto the belt and see if the noise goes away. This is NOT a fix; just a tool to verify it's the belt and not a bearing. If the noise goes away, replace the belt. I like the Goodyear Gatorback belts.
Old Jul 25, 2005 | 04:33 PM
llwta's Avatar
Thanks for your resp. guy. I rep. the belt and I still have the noise. When I put on the A/C the noise increases. The noise goes away after 5 or 10 min. of running. A piece of gas line hose says it's the A/C clutch bearing.
akwa
Apr 5, 2015 05:09 PM
BigWil
Mar 29, 2015 12:24 PM
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
