Bearing on the spider of the driveshaft...
Old Apr 23, 2003 | 10:04 PM
96z's Avatar
96z
I just recently got a 1LE driveshaft and the bearings on the spider easy slide off and on...my stocker didnt do this when I compared them...is this ok...or even the way its suppossed to be?
Old Apr 23, 2003 | 10:41 PM
You are referring to the u-joint bearing caps. I think the stock ones have a metal clip that helps keep them on. It is ok if they move freely as long as there is no perceptible slack in them.
Old Apr 23, 2003 | 10:48 PM
96z's Avatar
96z
Rob, there is no absolutely no slack, they just move freely. Oh and I did check the stocker and there are little clips that keep them in place like you said....once I tighten these down with the clamp that mounts to the differential housing it should keep them in place right?
Old Apr 23, 2003 | 10:52 PM
They definitely will not go anywhere when bolted in. Just make sure you get the caps fitted inside the little tab in the yoke. It is a tight fit.
Old Apr 23, 2003 | 11:57 PM
Prince's Avatar
Although I'm using a stocker, I had it balanced and new U joints put on. I too have to compress the caps (just squeeze it w/ my fingers) to get it to fit into the yoke.
Old Apr 24, 2003 | 11:16 AM
96z's Avatar
96z
Cool, thank guys.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
