bbk u/d pulleys..need help
Old Nov 6, 2004 | 06:05 PM
camzaro28's Avatar
today i took my car to another guy on the board, and we treid to do this swap. he got the 3 7/16'ths bolts out. then he couldnt get the balancer off! we tried for like 2 hours, anyway he sprayed it with some shiat, and kept trying but it was a no go. any suggestions to get this thing off? thanks in advance
brian
Old Nov 6, 2004 | 06:42 PM
camzaro28's Avatar
Re: bbk u/d pulleys..need help
na, in the instructions i now it dont show that! thank u though
Old Nov 7, 2004 | 09:19 AM
It gets "sandwiched" between the stock damper/pulley and the hub.
When the cars were new, if you pulled the 3 bolts out, the damper would fall off. Rust has made many near impossible to remove. Sometimes a few taps with a hammer will help. Otherwise, you need to use a 3-jaw puller. Shoebox has the info on his "Tech Pages". Avoid tapping on or pulling on the outer diameter of the damper - you can damage it.
http://shbox.com/1/pull_pulley.jpg
Old Nov 7, 2004 | 10:38 AM
tonylittell's Avatar
aright then what do you do to get the hub off also as i need to get to the cam?
Old Nov 7, 2004 | 12:16 PM
camzaro28's Avatar
thanks injuneer! that is what i needed! one day i will be sending u money, seems like u have all the answers to my camaro problems.
later
truecontr3
Oct 11, 2015 09:30 AM
95craz28
11
Sep 12, 2015 07:47 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
alphaauto
Jul 26, 2015 04:40 PM
colts0455
Jul 24, 2015 04:51 PM
