Bbk shorty header for lt1 lost a part
Old Oct 24, 2016 | 10:45 AM
Travist24's Avatar
New to the group. I have a 1996 z28 with a 383 LT1. Built T56 and 4.10 gears. I bought the car as is and plan on upgrading it slowly.
But first I have a question.
So I was getting on the freeway and heard a pop.
Opened the hood and noticed that my driver side header had an opening and I can't find the replacement part. Attached is a picture. Thanks for the help. The headers are bbk shorty for lt1.
https://goo.gl/photos/cBz7CaVccrsgDntR8
There is The link To the photo
Old Oct 24, 2016 | 10:51 AM
Travist24's Avatar
Re: Bbk shorty header for lt1 lost a part
Having a real problem getting Google photos to link the photo. Any advice?
Old Oct 24, 2016 | 10:56 AM
Travist24's Avatar
Here is a link to the album
Old Oct 24, 2016 | 11:57 AM
Chimera96's Avatar
is there threads inside that nipple?
if so just get a threaded bolt/plug the size you need
If the threaded part just broke off, get it welded shut
That nipple was for the air check valve. part of the air pump system (emissions)
Old Oct 24, 2016 | 07:29 PM
Pullngz's Avatar
An old o2 sensor should plug the hole up, I am taking for granted that this wasn't hooked up to the A.I.R system, and you lost the plug that was in there.
Mike
Old Oct 24, 2016 | 10:57 PM
The early years can be plugged with a 22mm oil drain plug. Use a copper gasket on the plug. Later years were 17mm. But that looks like the 22mm size.
Old Oct 24, 2016 | 11:01 PM
PS - you photo address has to have a .jpg extension to work. Google address is not in that format. You also had a double http:// typed into the address at the top of the first post. I corrected that, but then realized the file names don't have a workable extension.
Or, upload to an album here:
https://www.camaroz28.com/forums/sit...28-com-699204/
You can copy the BB code from under each picture and embed it in you post.
Note plugged AIR connection on header.
CamaroZ28.Com Message Board - Injuneer's Album: Injuneer's 94 Formula - Picture
Old Oct 25, 2016 | 12:39 PM
Travist24's Avatar
Understood. Thanks for the heads up. And thanks to everyone for their assistance. This is my first "newer" Chevy and so far she has been a blast to drive.
I live in the bay area of northern California, does anyone know a reputable shop that specializes in LT1 performance?
Thanks again
