battery question
Old Jan 21, 2008 | 03:56 PM
94 Z28's Avatar
battery question
I'm having a problem with my battery going dead every other week. It's a new battery but something is sucking the juice right out of it. I've had the alt. checked and it was fine. Any suggestions?
Thanks guys
Chris
Old Jan 21, 2008 | 04:07 PM
n2ceptor's Avatar
Corrosion??? Do you have an aftermarket radio/amp???? Map light on??(located rearview mirror)
Or it might be a bad cell in the battery.......
Old Jan 21, 2008 | 04:43 PM
94 Z28's Avatar
No Corrosion, stock radio and I checked all the lights. This is the second battery..
Chris
Old Jan 21, 2008 | 05:16 PM
Guest47904's Avatar
Guest
Check current from the battery with a multimeter in line one of the battery cables while everything is off. Any amps or anything connected directly to the battery should be checked first.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
nosliw
Feb 7, 2015 01:30 PM
capebuf
Jan 13, 2015 07:22 PM
97z28k&N
Jan 9, 2015 04:58 AM
nophix
Nov 30, 2014 10:26 PM
