Battery died TWICE within month.??
Old May 3, 2004 | 10:45 AM
crAzy95z28's Avatar
well i thin kbaout 3-4 weeks ago my car wouldnt start cause the battery was dead....so i take it to get charged, fully chagred good battery it said...drove it for about 3-4 weeks then this morning my car doesnt start again due to dead battery...WHAT IN the WORLD is causing my battery to die???????????
please help
Old May 3, 2004 | 10:46 AM
crAzy95z28's Avatar
i have a radar detector that nevers goes off over night!
Old May 3, 2004 | 10:48 AM
BlakeW5's Avatar
Has the alternator gone bad?
Old May 3, 2004 | 10:50 AM
crAzy95z28's Avatar
nope...charges just fine when car is running.....never have problems when car is running though....
Old May 3, 2004 | 12:06 PM
BlakeW5's Avatar
D@mn, that's all I had . Guess it could be the radar detector then. If that's what you think is causing the problems why don't you just unplug it at night?
Old May 3, 2004 | 02:26 PM
crAzy95z28's Avatar
i woulndt think such a small source would cause my battery to die......
Old May 3, 2004 | 02:28 PM
Tair's Avatar
yea, why not wire that radar detector to an ignition wire rather than a constant?
Old May 3, 2004 | 02:30 PM
sabre81's Avatar
what brand radar detector do you have?
94Sleeper's Avatar
You have a parasitic current draw that is draining your battery. I'm guessing that when you drive the car every day it works fine, but if you don't drive it for a few days its dead.
You will have to track down the offending circuit. In my case my console light switch never extinguished the console light and drained my battery in a couple of days.
Check out this post for some good troubleshooting tips:
Current Draw Troubleshooting
Old May 3, 2004 | 03:09 PM
crAzy95z28's Avatar
well i have the radio shack deector the most expensive one...which works pretty well....but also i have a constant static noise comming from my passenger front speaker and i replaced it thinking it was busted but ended up being a wire touching something to my ground, specially when i go over a bump or somehting it makes loud as static noise......
lemme know ill bbl interveiw at 4pm...its now 3:15
randy
walt355
Mar 16, 2016 09:35 AM
weedog
Aug 15, 2015 08:23 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
