battery or alternator?
Old Jun 23, 2006 | 06:42 PM
nodnarb481's Avatar
So I watch my guages religously, while the car is "on" and while the engine is running. When the engines running im showing 14ish volts all the time its always steady. But for a while now I've noticed it getting harder and harder to start. I would put it to "on" (i usually leave it there for a second or two and just check over the vokt guage) it used to be higher maybe right around 12 but then last night it was lower and it cranked really low and started. then today it has about 8 when its "on" and i tryed to start it and its just nothing.
im pretty sure its the battery but i figured id get some opinions anyways
Old Jun 23, 2006 | 07:03 PM
Laymaster's Avatar
Re: battery or alternator?
sounds like a battery. how old is your battery? they typically last 5 years.
Old Jun 23, 2006 | 07:09 PM
The Engineer's Avatar
The 14 volts with engine on, is your charge (float) voltage and that indicates your alternator is working correctly. Typically the charge voltage is 1 1/2 to 2 volts greather than the battery (12 volts).
Your car battery alone is 12 volts, therefore if you go "iginition on" (engine not running) and you're only indicating only about 8 volts, that is an indication the battery is bad and not taking a charge. Or, you could have a bad battery connection dropping some voltage.
Old Jun 23, 2006 | 08:15 PM
Kevin Blown 95 TA's Avatar
A battery is 12.6 volts. Each cell is 2.1 volts. A battery that shows 12 volts is slightly discharged.
Old Jun 23, 2006 | 11:11 PM
nodnarb481's Avatar
well the battery is chillen in my garage right now and im gonna get it checked tomorrow and if its bad then ill buy a new one.. what kind of battery should i buy? i dont want to spend a fortune because unfortunate for my timing.. my car is going to my neighbor on monday to have the transmission built up (FOR FREE!!!!) but i gotta buy some gaskets a filter and fluid so money isnt very short.. but short none the less
Old Jun 25, 2006 | 03:13 PM
nodnarb481's Avatar
whatbattery am i supposed to get? I have the battery pepboys gave me in the car and its pushing up on the rubber piece behind the headlight and it looks like its pinching some tube thats between the headlight housing and the battery. It looks like its just too big... the battery they gave me is
group-75
size-9074222
part#75-650e
and when i tighten the bolt for the hold down clamp it never makes the battery snug it just seems like its going to then comes off the little edge of the battery and thats it
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
Pwilson59
Sep 3, 2015 08:47 PM
