bas gas fumes [ trunk area]
Old Sep 23, 2003 | 04:54 PM
ramair94ta's Avatar
since i bought the car ive been getting bad gas fumes in the car when driving, it seems to be coming from the truck area by the tank, is there any vent back there for the gas tank or just the gas cap [ new cap] what can this be , my be i'll pull the tank and see what on top of it .
thanks for any help
Old Sep 23, 2003 | 06:20 PM
First look things over for leaks. If there are none, its probably related to the "EEC" vapor collection system. There is a carbon canister in the drivers rear fender, behind the fill line, and a couple of lines that connect the canister to the top of the fuel tank. The lines may be rotten or loose (common problem), the pressure relief valve may be open, the canister may be saturated with fuel. The problem will be made even worse if your fuel pump is failing, and overheating the fuel in the tank, increasing the vapor load to the canister. Another possibility is that the "purge" system on the engine that pulls the vapors out of the canister may be messed up - failed purge solenoid, plugged line from the canister to the solenoid, cracked vacuum line from the solenoid to the throttle body.
You can examine the canister by removing a plastic panel inside the fender well. But the lines are very hard to see/follow because they go up and over the tank.
Old Sep 23, 2003 | 07:32 PM
ramair94ta's Avatar
looks like i better get started and find the problem, will it pull a code if it is a solenoid or canister.
Old Sep 23, 2003 | 09:57 PM
DarkHorse's Avatar
I have this same problem. Gonna try the nifty search function to find out more about the system. Thanks
Old Sep 24, 2003 | 01:39 PM
The only code you can get in an OBD-I (93-95) is DTC 26, indicating an electrical problem with the purge solenoid.
May 8, 2015 11:30 AM
Dec 4, 2014 11:56 AM
squarehead
Nov 21, 2014 08:02 PM
simple
Aug 11, 2002 11:56 AM
Wilson
Jul 21, 2002 05:08 PM
