Bare block in the car...Will it very easily pull out?
Old Oct 30, 2006 | 06:32 AM
wrd1972's Avatar
Right now my bare block is sitting in the car awaiting heads and cam but I have some bad cam bearings. After dettaching the tranny will the block and bell very easily lift out from the top with a cherry picker?
It sure appears that it would, am I wrong?
Old Oct 30, 2006 | 06:48 AM
SnakeOiler's Avatar
It will come out without a problem.
Old Oct 30, 2006 | 10:14 AM
Sweetred95ta's Avatar
I agree. Are you going to assemble it outside of the car? It can be dropped back in with the heads on it, too.
Old Oct 30, 2006 | 10:20 AM
wrd1972's Avatar
I may do that. I dont mind putting the heads back on with the block re-installed. The extra time does not bother me.
But right now I am really trying to determine if the block with tranny attached will easily come out through the top. If that is going to be a headache I will unbolt the tranny.
Anyone want to chime in on this?
Old Oct 30, 2006 | 10:29 AM
wrd1972's Avatar
Is it possible to pull the block out with the tranny still attached through the top?
Old Oct 31, 2006 | 10:57 PM
96SSM6's Avatar
yes it will come out w the trans attached. i would recommend reinstalling through the bottom though, compete.
Old Nov 1, 2006 | 12:46 AM
00JoeZ28's Avatar
When I did my motor swap, I was able to pull it from the top and drop it back it through the top with no problems. And yes the tranny was attached, but the intake off.
All it took me was a good cherry picker and a leveler.
Old Nov 1, 2006 | 02:46 AM
96SSM6's Avatar
through the bottom and you dont have to do anything but plug things in. both methods work, but one is less work (if you have the tools). ive done many this way and i have lots of pictures if anyone would like to see.
Old Nov 1, 2006 | 12:22 PM
Eddie Z-28's Avatar
This is exactly what I did when I did my heads and cam. I originally was going to put everything back on the 97k stock bottom end, but when I thought about it, they money was well invested in a rebuild. I had everything off the motor and decided to pull it. It was a bare block, and came out no problem. Have the motor assembled, and drop it back in through the top. When you do it, have lots of guys around to give you a hand, because it's tricky. Good luck and let us know how it goes.
Sergio
Jan 27, 2016 04:27 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
wildchild
Sep 9, 2002 09:12 AM
wildchild
Sep 6, 2002 12:07 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
