Ball Bearing
Old Jul 14, 2004 | 05:55 PM
Toker420's Avatar
Ball Bearing
Im ready to start puting on my main caps and in this book i got says there shoudl be a ball bearing that goes in the block under the last main cap where the oil pump goes. Is it nessacary to have this in cause i can't find mine?
Old Jul 14, 2004 | 06:13 PM
n2ceptor's Avatar
According to the HP book rebuilding the LT1; if you leave it out. you will loose oil pressure and have an oil leak at the rear cap...
Old Jul 14, 2004 | 06:19 PM
Toker420's Avatar
where can i get one ?
Old Jul 14, 2004 | 06:33 PM
jkipp84's Avatar
Probably from Jason Cromer or Dal, a search on either (both) of those will get you the contact info. Or perhaps someone will chime in...
Old Jul 14, 2004 | 07:04 PM
Dave88LX's Avatar
It's a .473" steel ball. You can get one from GM or from a ball bearing manufacturer (Yellow Pages?).
Old Jul 14, 2004 | 11:56 PM
Toker420's Avatar
Thanks for the help.
Old Jul 15, 2004 | 06:00 PM
arnie's Avatar
It could be a 'cup' type plug (similar to freeze plug), of the correct dia., as well.
Old Jul 19, 2004 | 10:28 PM
engineermike's Avatar
Re: Ball Bearing
Is this the bearing that segregates filtered versus non-filtered oil?
Old Jul 20, 2004 | 06:12 AM
arnie's Avatar
Re: Ball Bearing
Yes! It plugs the connecting passage of the unfiltered to filtered circuits.
Ericksd
Jan 20, 2016 06:07 PM
n2oblkz
Oct 22, 2015 02:31 PM
Bxlt1
Sep 29, 2015 03:18 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
