Balencer Hub Bolts ?
Old Dec 19, 2009 | 04:35 PM
starbucks's Avatar
Hey guys I have a quick question regarding my balancer hub. Well some how the bolt holes on my balancer hub have gotten stripped so what I have done is drilled and taped all three hole from 7/16 to 1/2 inch. My question is, is this going to mess with the balance of thing or should I be fine?
Old Dec 19, 2009 | 04:52 PM
JAKEJR's Avatar
You'll be fine; that small weight difference amount won't be a problem.
If you want a second opinion, weight a stock bolt and the replacement and see the difference. Or you could weigh all three Vs all three to get the total weight difference.
Not sure how sensitive the Post Office scales are, but they'd be worth a try if you don't have a scale.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 19, 2009 | 05:06 PM
starbucks's Avatar
Thats what i was thinking but on a fresh motor i wanted to be sure.
Old Dec 19, 2009 | 09:02 PM
JAKEJR's Avatar
Don't fret, I'm the same way too, meticulous on a lot of things that other simply skip over. Hell, I've even called Hendrick MotorSports (of NSACAR fame) on questions I've had.
Once you have the numbers, you can run them by a machine shop that you trust - I recommend one that specializes in racing engines - and see what the balancing guy says.
Remember, it's pretty easy to make any needed balance adjustment right now if it's called for. I confident that no mod will be needed though.
Jake
Old Dec 20, 2009 | 08:32 AM
97WS6SCharged's Avatar
It shouldn't make a difference, but if you're that worried about it you can always buy a new hub.
Old Dec 20, 2009 | 11:15 AM
Think your way through it. The closer to the axis of rotation, the less effect the weight will have. As long as all the bolts are the same weight, it would not affect the balance as long as the arms on the hub were symmetrical.... but they aren't. They are unevenly spaced, meaning the 3 bolts will not be evenly spaced. But then the stock bolts were not evenly spaced either. The tiny weight difference of the 1/2" bolts compared to the 7/16" bolts is not going to be noticeable, when its located to close to the centerline of the crank.
And... its not a "balancer", its a harmonic damper.
If you are concerned, have the damper/hub assembly neutral balanced. That's what the holes around the edge of the damper are for.
Old Dec 21, 2009 | 07:12 AM
JAKEJR's Avatar
LOL, I see you do the same thing I often do, since I feel it's best to call things as they are. Seems some get offended by being corrected though. Oh well . . .
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 20 May 2010!!!
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
