Balancing Question
Old Jul 22, 2005 | 08:31 AM
383TransAm's Avatar
Question Balancing Question
I had my 383 Stroker Assem. Balanced when I bought it. The place that did it asked for the flywheel & clutch (it was the stock flywheel) that I was going to use.
My quesion is: Am I going to run into any problems putting on a new SLP Steel Billet flywheel?
Old Jul 22, 2005 | 09:03 AM
OBE1 95Z28's Avatar
Re: Balancing Question
If the rotating assembly was balanced using a stock flywheel, then the SLP flywheel will work just fine. The SLP flywheel is lighter, but balanced the same as the stock flywheel.
Old Jul 22, 2005 | 09:30 AM
blackztpi's Avatar
the stock flywheel is externally balanced. you'll want to line up the flywheels to see if the wights are in the same place. it never hurts to have it checked at a shop if it looks any different.
Old Jul 22, 2005 | 11:14 AM
383TransAm's Avatar
OBE1 95Z28 , that's what I was thinking but I wanted to make sure
I will check them both out when I get it apart but I should be
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
Jason Short
Jan 19, 2015 06:33 PM
