Balancing issues
Old Jun 29, 2003 | 01:12 PM
steve10358's Avatar
3rd Gen Tech Moderator
Balancing issues
I have a forged crank, eagle H beam rods, and some speedpro pistons. I am going to have everything balanced, but my question for you guys is this:
What should I do about the external balancer? I am going to run a Procharger P1SC, and am curious as to what will work, etc?
Thank you!
STeve
Old Jun 30, 2003 | 05:19 AM
slopokrodrigez's Avatar
Is your crank broached for a key at the hub? It should be for a blower. Most after market Mfr's of balancers make theirs with keyways. I have a fluidamper and it is keyed. The super damper from ATI is also keyed. Avoid the fluidamper. I know from experience it will rattle your teeth out until it warms up.
Old Jul 1, 2003 | 12:01 PM
tubby's Avatar
i have a fluid damper with ati procharger and it's fine but make sure if you are internally balancing to nuetral balnce the flywheel or flexplate
Drtryder
Apr 22, 2015 04:17 PM
eanhl2004
Apr 4, 2015 12:01 PM
F550maranello2
Apr 1, 2015 11:10 AM
derty
Jul 16, 2002 12:20 PM
