Balancer Woble on 383
Old Nov 9, 2007 | 03:02 PM
awdfun's Avatar
Okay here is the story. I built this motor. I am using a Eagle stroker kit.
I ran into problems with the t56 flywheel not being neutral balanced, so I had that problem fixed. The engine needed new bearings because the bearings where shot (Only 500miles on engine). I got all the bearings replaced, Flywheel neutral balanced, put the car back together. Start the car, Runs very smooth, notice the balancer has a slight wobble. I bought a new keyed crank hub and a new jegs sfi balancer. It still does the same thing. Pulled the motor out today, took it apart, put a dial indicator on the nose of the crank, no movement, straight as can be. I put the both keyed hub on the crank and rotated it is off a couple of thousands .003, on the hub. I am going to take the whole RA including flywheel, keyed hub, and balancer to get rebalanced. Would balancing the whole RA fix this problem? The front balancer damper moves a lot when the engine is running. Could the crank be flexing? It is very noticeable at idle.
Old Nov 9, 2007 | 03:30 PM
GaJoe's Avatar
was there any other noise when the motor was running? You could have a cracked crank but I would suspect some noise...
Old Nov 9, 2007 | 03:48 PM
awdfun's Avatar
no noise. engine runs very smooth.
Old Nov 9, 2007 | 04:27 PM
Kevin Blown 95 TA's Avatar
Either the hub is bent from pulling it off or the balancer is machined wrong. i would take those two parts to the shop and ask them to check them before you do anything else
Old Nov 9, 2007 | 05:01 PM
Is there any evidence of the crank moving forward and backward in the block? May have too much end play.
Old Nov 9, 2007 | 05:57 PM
awdfun's Avatar
I tried 2 different hubs and 3 different balancers.
I have a stock, Professional Products, and a Jegs SFI balancer
Old Nov 9, 2007 | 05:58 PM
awdfun's Avatar
End play is tight. I put new bearings in.
Old Nov 9, 2007 | 07:01 PM
Wow, Sorry I reread your post and see that you tried a few different things. Wonder if it is shaking and you can't tell. Do the dampers have rubber in them? Or are they solid metal?
Old Nov 9, 2007 | 07:42 PM
awdfun's Avatar
The Jegs SFI looks like it has rubber on it, the stocker and professional product damper have rubber. It is very weird. I am hoping it is just unbalanced. I dont want to pay for a new crank if its cracked.
Old Nov 11, 2007 | 02:30 PM
awdfun's Avatar
Okay. After banging my head a couple of times I think I found the problem. I have a LT4 Extreme Duty timing chain on the engine, The crank sprocket is machined wrong. I took and measured the thickness of the sprocket and in some places it measures .208 and if you move around it i get a thickness of .220. I put a stock crank sprocket on the engine and reinstalled the hub and checked the runout and it was near perfect. The lt4 sprocket was causing the hub to bend a little bit.
Old Nov 11, 2007 | 02:50 PM
WS6T3RROR's Avatar
As much as that thing costs to have runout like that, what a bunch of horse ****.
Old Nov 11, 2007 | 07:29 PM
1racerdude's Avatar
Send it back--Get another one--- Tell them to put that one where the sun don't shine.
Old Nov 11, 2007 | 08:02 PM
awdfun's Avatar
I bought the timing chain last november
Old Nov 11, 2007 | 09:03 PM
1racerdude's Avatar
And you have had a problem ever since and just found it.
They would want to know.
Old Nov 12, 2007 | 05:39 AM
awdfun's Avatar
No. It has been a long process of building this car. I only have 500 miles on it
