Balancer went bye-bye!!!!
Old Mar 23, 2014 | 07:50 PM
1996LT1Z28's Avatar
My son calls me - frantic as all hell, and said that the balancer on his 96 Z28 came off in front of his girlfriends house.
Sure enough, the balancer was in his hands when I arrived. He was a little pissed to say the least.
I remember that when we put it on after we changed the seal, it went on real easy....now the $10,000.00 question.
The balancer should be more of a press-fit than just an easy slide-on??? Right?
I'm thinking the crank twisted inside the hub, and loosened the mounting bolt at the same time.
Is my thinking correct? I guess I need to get a new hub.
Old Mar 23, 2014 | 08:08 PM
Re: Balancer went bye-bye!!!!
Yes, the damper (not a balancer) is a press fit and typically requires a length of grade 8 threaded rod to pull it on.
Old Mar 24, 2014 | 05:19 PM
Trinity Rx7's Avatar
More than likely the outer "pulley" part of the damper came off and the inner part is still bolted on. A stock damper is 2 pieces that over the time the plastic or rubber that holds them together comes apart.
Old Mar 24, 2014 | 08:24 PM
1996LT1Z28's Avatar
Nope!!! The whole thing came off. Believe me.
Just ordered a new hub.
Old Mar 29, 2014 | 01:43 PM
Chimera96's Avatar
OP, the hub is a "press" fit and should take some effort with the proper install tool to put on.
You can buy keyed hubs or have a machine shop cut one in...IMHO always a good idea
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
