Balancer Question
Old Oct 10, 2008 | 01:32 PM
dustin_mcgowan's Avatar
Balancer Question
I have a 1994 Z and I just put a diffrent motor in it. I had to use the Balancer from my motor on the new 96 motor. Would this cause problems?
Old Oct 10, 2008 | 03:06 PM
n2ceptor's Avatar
Accord to Dorman 93~97 LT1 uses same harmonic balancer...
Old Oct 10, 2008 | 03:07 PM
It's not a balancer. It's a harmonic dampener/pulley. The hub length could be an issue, depending on which hub you used. If you only swapped the pulley, you should be ok.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
Jason Short
Jan 19, 2015 06:33 PM
