balancer
Old Jan 15, 2009 | 09:55 AM
White Lightning's Avatar
balancer
anyone ever try to put an old school small block balancer on a lt1? i got rid of the optispark
Old Jan 15, 2009 | 12:18 PM
camarobird92's Avatar
Remember that the LT1 is neutrally balanced in the front and doesn't use a balancer. It is a harmonic damper. Most of the SBC's are externally balanced. Other than that, it would physically go on there and fit. It just wouldn't work because of the balance issues.
Old Jan 19, 2009 | 09:20 AM
anyone ied this before?
Old Jan 19, 2009 | 09:49 AM
Stl94LT1's Avatar
The LT1 balancer is also a serp belt pulley. What would you use for the pulley?
Old Jan 20, 2009 | 08:57 AM
i was just gonna run a v belt , all i need is for the alternator, i dont have alot of room. im using a pt88 turbo
Old Jan 20, 2009 | 01:13 PM
MachinistOne's Avatar
A standard SBC damper will work - Pioneer makes nice aftermarket standard and performance series dampers that are affordable, your local machine shop can supply them.
Old Mar 14, 2009 | 08:51 AM
350350's Avatar
That Turbo is bigger than my living room.
God Bless You!!!
Old Mar 14, 2009 | 09:34 AM
cnorton's Avatar
I set it up that way on my Super Stock LT1 with no problems. Part of the good news is that you can use an early timing pointer and a small block crank trigger right out of the box.
c
Old Mar 14, 2009 | 11:05 AM
PWR SHFT's Avatar
Not true. The only small block that was externally balanced was the 400. It used a special harmonic balancer with a counter balance weight added along with a matching couterweighted flywheel. All other SBC were internally balanced.
Even though the newer SBCs (including the LT1) need a special flywheel with balancing weight due to the elimination of the external crankshaft counterweight with the one piece rear main seal, it is still considered internally balanced.
Jeff1904
Jun 5, 2016 05:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
karpetcm
Aug 14, 2015 03:02 PM
bunker
Aug 1, 2015 10:10 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
