Baer Track Brake Kit
Old Feb 9, 2004 | 08:13 PM
solid's Avatar
Has anyone had these installed by someone who can do it right,and not at an outrageous price? im in N.J. and Im willing to travel for a job well done.
Old Feb 9, 2004 | 09:41 PM
96SS232's Avatar
I installed the ZO6 conversion in my SS myself. If you want to take a drive down 95, id do i for you, but thats a long drive. Its really not all that hard. Have you bought the kit yet?? if not i would really recommend that you get the ZO6/C5 conversion. It uses a stiffer caliper, larger pad, thicker rotor, and has a lot more pad options. the track kit is a good upgrade though.
Old Feb 9, 2004 | 10:11 PM
Bud M's Avatar
You can easily do it yourself in an afternoon. You will need a sawzall with a few spare blades and its not a bad idea to have an electric grinder too. You put the car on jacks, remove the front wheels and stock brakes, use the sawzall to trim off part of the steering knuckle (keep it oiled as you cut or you'll go through more blades), clean up the cut with a grinder if you want to, and bolt on the Baer kit (the Track kit requires 17" wheels) and bleed them.
Old Feb 9, 2004 | 10:17 PM
TMorgan800's Avatar
You will need to trim off the steering knuckle and 17" rims. I took mine to my buddy @ a dealership and their brake guy did it, reluctantly. Said it would have cost about 300 bucks.. I dunno. they did it for free.. :-) mu haha
Old Feb 9, 2004 | 10:41 PM
solid's Avatar
Thanks for the replys.
Old Feb 9, 2004 | 10:51 PM
Jason Dove's Avatar
Buy some cutting oil and you won't use up any blades. I didn't wreck any blades 'after' I started using it when my Baer kit went in.
Old Feb 10, 2004 | 12:19 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
go with the Z06 and do it yourself. here is all the info.
http://web.camaross.com/forums/showt...hreadid=221457
david
Old Feb 13, 2004 | 07:16 PM
96LT1Fan's Avatar
I don't believe that 17s are absolutely necessary. Someone on this board was able to squeeze the track kit into their 16 inch shooter (which is what I plan to do within the next year or so).
Old Feb 13, 2004 | 07:21 PM
Chris 96 WS6's Avatar
instructions for the C5/ZO6 intall can be found here:
photos are from when I did it 2 yrs ago, basic instructions for the track kit would be the same. The key is having good blades in the reciprocating saw.
http://mtfba.org/racingsystems/Brake...stallinstr.htm
Old Feb 13, 2004 | 09:31 PM
solid's Avatar
Thanks for the information, I will try the installation when the weather gets better, in the mean time Im saving the information for when Im ready to do it.
Old Feb 13, 2004 | 10:07 PM
OBE1 95Z28's Avatar
17" rims are a must if you're installing the Baer Track Kit with 13" rotors. Not all 17" rims have the same ID; Baer has a webpage that will allow you to print out a "brake profile" to check your rim size. My Enkei Winn 17" rim ID is too small for a C5 setup; but just barely cleared (0.1") the Baer 13" Track Kit.
Old Feb 18, 2004 | 07:48 PM
96LT1Fan's Avatar
Whoops... It's the Sport kit w/ 12" rotors that someone was able to squeeze into their stock 16" rims. My mistake.
Old Feb 18, 2004 | 09:41 PM
Bud M's Avatar
Yeah, I ran the Sport kit with stock wheels. They fit fine.
Old Feb 18, 2004 | 10:04 PM
Rock_N_Rolla's Avatar
I have the Baer track kit installed and it's great, however replacement rotors are very expensive. I'd go with the C5 upgrade, almost as good and cheaper rotors.
BTW, get plain rotors, no cross drilling, they'll crack at the track.
If your not going to the track don't bother to upgrade just get better pads and spend your money elsewhere.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
slocody
Feb 10, 2003 01:04 PM
