Bad Vibration
Old Feb 1, 2004 | 11:57 AM
NasT 99Z's Avatar
Arrow Bad Vibration
The car is a 93 Formy , new brakes new tires. has a bad vibration ..Not really noticeable until like 70 mph...what do u guys think..I was thinking driveshaft....any help would be great
Old Feb 1, 2004 | 12:00 PM
LPEdave's Avatar
Yep, the driveshaft is a very common problem on these cars, your symptoms sound like it. There are a few reasonable options, including the GM 1LE or LS1 driveshafts to replace it. Getting yours balanced may or may not help, but it's a cheaper option. Cheapest yet is to rotate the driveshaft 90 degrees in the yoke which is worth a shot.
Dave
Old Feb 1, 2004 | 12:21 PM
95firechicken's Avatar
lingenfelter has 3.5" alum driveshafts on sale for 299
Old Feb 1, 2004 | 12:30 PM
NasT 99Z's Avatar
cool guys thanks for the help...I got a shop that will make me one balanced and all for 150... thanks for the help
Old Feb 1, 2004 | 12:33 PM
Zack's Avatar
if you feel it in the steering wheel, could be the balancing of the wheels
Old Feb 1, 2004 | 01:56 PM
94blackz14.2's Avatar
Check out your u joints first. I know that I had a very bad vibration and it turned out to be my u joints were bad.
Old Feb 1, 2004 | 02:42 PM
Robert95z's Avatar
My vibrations start at 80mph... So i switched to a LS1 driveshaft, and the vibrations didnt change at all... I noticed the Rear ujoint on the LS1 driveshaft is pretty stiff, is that normal?
Vibration is underneath the console and sounds pretty violent
Old Feb 1, 2004 | 02:53 PM
c0rey's Avatar
I get bad vibration under the console as well, I still have the stock driveshaft, All I know is that it makes alot of noise.
Old Feb 1, 2004 | 03:12 PM
Mine still has a little bit of the vibration, and it feels like it is coming from below the consoul. That is right were the tail shaft of the transmissoin is. This makes me wonder if the tail shaft bushing on my A4 is worn out and has too much play in it. Just might be something else to look at. I think that the bushing itself is only about $7 at gm, I have just been to busy to take care of it.
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
mattszm6
Dec 14, 2014 07:09 AM
