bad thermostat?
Old Nov 1, 2005 | 12:28 AM
romoranger's Avatar
bad thermostat?
basically my car has never had over heating problems. i would sit in summer traffic in arizona at just over 185 degrees. i did a cam swap, the car ran a bit hotter, put a new a/c compressor in, car would never get over 210 even sitting in standstill 112 degree traffic. lately now with no a/c on or with on the car will get to and sit at 235 degrees. before when i had no a/c it would hang out at 185 or lower just driving around on the highway. i am not sure what it is. there is no air in the system i am sure of that. i have a manual fan switch that is always on. i am thinking maybe a bad thermostat? what does everyone think?
oh yes, and the car has a 160 degree thermostat that certainly probalby has at least 100k miles on it that i know of. car currently has 136k miles.
Old Nov 1, 2005 | 07:25 AM
Re: bad thermostat?
You can remove the thermostat and test it in a pan of water. Make sure you have not sucked up any debris in front of the radiator.
Old Nov 1, 2005 | 11:41 AM
teke184's Avatar
Re: bad thermostat?
isn't the thermostat designed to fail in the open position??
i say check it..
but it could be that you're waterpump is failing or that you have a blockage in your radiator.
Old Nov 1, 2005 | 12:39 PM
faded93bird's Avatar
Re: bad thermostat?
Yeah check to see if she ate something, these cars are bottomfeeders. Also check to see if your primary fan is still working, the motor may have taken a dump. (I got a couple of extras sitting around )
Faded
Old Nov 1, 2005 | 04:41 PM
romoranger's Avatar
Re: bad thermostat?
i'll take a look at the fans, then i'll check the radiator.
Zuvell
May 15, 2015 08:18 PM
Britbilly
Jan 7, 2015 08:49 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
