Bad Starter...Again?
Old Mar 14, 2008 | 04:25 PM
neil350's Avatar
I swear I have zero luck with starters, the car does this randomly, but when you turn the key, you get nothing, starter is dead. Then eventually you turn it enough, it will crank and then start up. It could go a few weeks and never do this again. So far its always started just gotta turn the key a bunch of time, battery is always left on maintainer to retain charge. The car used to do this when an old starter I had went bad a few years ago, but it was only when the car was hot. Now it does randomly, I can see the volt gauge move when I try and crank it, so power is going some where. Just seems like the symptoms of a starter going out. Only other thing I could think is maybe an ignition switch, but I can see the volt gauge move, the cars sending power to try and start, the starter isn't either getting it or not working.
Old Mar 14, 2008 | 09:00 PM
LT1BanditTA95's Avatar
So it " click click clicks? at first when you turn the key? as if the starter is goin?... if thats the case you need to check yourbattery connection...
Old Mar 14, 2008 | 11:10 PM
neil350's Avatar
Nope no clicks, starter doesnt work at all. I know what the low battery sounds like, thats why I keep the car on a maintainer.
Old Mar 14, 2008 | 11:13 PM
Z95m6's Avatar
I would look at your ignition switch as a possible culprit, I'd also clean the connections on your starter.
Old Mar 15, 2008 | 08:07 AM
maverickmk's Avatar
also, make sure your connections at the battery are tight & clean
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
