bad running car
Old Oct 29, 2006 | 09:15 AM
Under_Pressure's Avatar
bad running car
Ok Here the issue.
The day before I sprayed it the ses light started flashing. It had Misfire detected cyl 3. The car acted very normal so I was confused as of why I did not feel it. That night I installed my 100 wet shot nitrous kit. I used a 47N and a 32F on power shots and a nos fogger.
I went to a long road with no traffic and sprayed her in 2nd gear at 4k RPM's. The car felt bad on the spray like it was missing on a couple cyl. I only sprayed it that gear. After that the car felt bad missing everywhere an running real poor.
The next day I went to work in it. The gas smell was bad, The code now was random misfire detected. I also noticed that the passenger mani was glowing. and the reserve tank of the antifreeze was smoking and bubbling but the temp was normal "the car was off".
Flowing night I removed the spark plug cables to see if any were cut and they all looked normal. I ordered new ones so I should be getting them soon.
Today I took off the fuel rail to see if the injectors were leaking and turned out they were ok. I checked fuel pressure and it was 45 with the motor off "no cables and fuel rail off" I did noticed the fuel pressure would drop after the pump was turned off, not too fast but I could see it fall.
Car has a new Opti, fuel filter, ignition modual and spark plugs.
its a 97 ws6 6 speed with a rebuilt motor "355"
Cliff notes: Car runs very bad, poor gas mileage, allot of gas smell when driving, glowing passenger manifold. All of this right after I sprayed it.
Old Oct 29, 2006 | 09:36 AM
jay_lt4's Avatar
take the plugs out and check them and while they are out time to check compression and leak down, just to verify you are working on a healthy engine and not wasting your time
why would you spray if you knew you had running issues, not a good idea
Old Oct 29, 2006 | 03:35 PM
Compression test results:
1: 200
2: 180
3: 210
4: 210
5: 200
6: 180
7: ?
8: ?
Havent done 7 and 8 yet Watching the Game!
I did notice my bank 2 air/fuel was loose when I took out the plugs. Do you think that could cause the codes?
Old Oct 30, 2006 | 04:45 AM
Guest47904's Avatar
Guest
Blown head gasket. Need to do a leak down test to find it.
Never EVER use NOS at part throttle. WOT only.
Old Oct 30, 2006 | 06:13 AM
I had a throttle switch so I was at WOT when I sprayed
Old Oct 30, 2006 | 06:29 PM
help?
Old Oct 31, 2006 | 09:42 AM
Anyone??
Red97LT1
9
Dec 17, 2014 06:13 PM
chuyz28
Nov 25, 2014 11:14 PM
USAirman93
Nov 24, 2014 03:37 PM
moneyshotz
Jul 27, 2002 06:16 AM
