Bad Opti?
Old Mar 6, 2004 | 04:43 AM
ollie-99's Avatar
Bad Opti?
I went out car was running perfect
then heading home whenever id stop it would just rev really low and die on me?
is this an issue w/ the opti?
Old Mar 6, 2004 | 05:51 AM
SS RRR's Avatar
Usually an opti will start acting up when there is load on the motor (i.e. accelerating). That sounds more like a posisble idle air control motor problem.
Pull it out and clean it as well as the bore in the throttle body where the plunger sits and see if that'll help out.
Old Mar 6, 2004 | 02:14 PM
ollie-99's Avatar
ok good ill give that a shot
thanks
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
May 17, 2015 10:18 PM
BLK1997Z28
May 7, 2015 03:01 PM
Noenav
Apr 30, 2015 01:06 PM
ad356
Apr 11, 2015 10:30 PM
