Bad Oil leak ON my OPTI spark Help
Old Apr 4, 2005 | 07:49 PM
crazypurgatory's Avatar
Question Bad Oil leak ON my OPTI spark Help
My 1997 Camaro Z28 has a bad oil leak.
I know its coming from the front cover.
I just can't tell where on the cover but it's getting my OPTI spark wet.
I have the seal for the water pump drive.
And the water pump gaskets.
I also have the front crank seal.
Which from what I can tell is a standard crank seal for all small block's from way back.
Is there a seal behind the OPTI spark?
I want to get all the seals before I tear into it.
Thanks,
Chris.
Old Apr 4, 2005 | 09:27 PM
Re: Bad Oil leak ON my OPTI spark Help
Yes, there is a seal.
Old Apr 4, 2005 | 09:54 PM
Thanks,
Shoebox.
Chris.
Old Apr 6, 2005 | 09:39 PM
y5e06's Avatar
yeah, make sure you get it taken care of or it may end up looking like this
http://www.vilipend.com/~frrax/clutc..._27_009?full=1
http://www.vilipend.com/~frrax/clutc..._27_008?full=1
Old Apr 6, 2005 | 09:57 PM
Question Re: Bad Oil leak ON my OPTI spark Help
Dam that's bad.
maby you can help me?
Check out my new thread.
http://web.camaross.com/forums/showthread.php?t=356143
Thanks,
Chris.
Old Apr 6, 2005 | 10:58 PM
Robs97Z28's Avatar
before you reinstall the opti. remove the rotor and put some rtv around base of the rotor. this will help keep any oil that will wick up though the hub. this is what killed my opti and gave me all of the troubles I was having.
HectorM52
Jul 30, 2017 11:46 AM
Iamherefornow
Jan 26, 2015 04:57 PM
artic94
Jan 17, 2015 11:19 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
96z
Sep 5, 2002 07:53 PM
