Bad Oil Leak
Old Aug 2, 2007 | 08:38 PM
a4z28's Avatar
Bad Oil Leak
I have just noticed an oil leak tha looks pretty bad can itbe coming from the back of the intake or the rear main seal. If it is the rear main seal is there any quick fixes or do i have to replace it. If so can i do it with the motor in the car or do i have to pull it thanks.
Old Aug 2, 2007 | 08:44 PM
Stl94LT1's Avatar
I'm betting it's the rear of the intake leaking. Rear main seal leaks are uncommon on these engines and all others with one piece rear main seals.
Old Aug 2, 2007 | 09:13 PM
a4z28's Avatar
I will check it out tomorrow i hope u are right.
Old Aug 2, 2007 | 10:32 PM
SS RRR's Avatar
It's very simple to check.
After the car cools down enough just stick your hand back where the intake meets the block. If you feel any oil especially on the crushed part of the sealent beed then you'll know your answer.
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
