bad mpg why?
Old Jun 5, 2009 | 10:08 AM
  #16
bw_hunter's Avatar
Your fuel filter may be clogged but it isn't causing your poor fuel economy. To change it:
1)Relieve the fuel pressure in the system. I told you how to do that before.
2) Jack up the rear of the car.
3) Crawl under and locate the fuel filter....it's on the inside of the frame rails and has a fuel line running in one side and out the other.
4) Armed with the right tools, some rags and a drip pan, simply remove and replace..it's pretty self evident how to do it....
Good Luck!
Your excess fuel consumption problem is something pretty big. In previous posts you mentioned raw gas smells, gas in the oil and blowby puffing out the oil filler cap. Now you're using about 40% more fuel than you think is right. I would think you have a bunch-o-black-smoke coming out the back of the car and that your O2 sensors are shot.
Old Jun 5, 2009 | 10:38 AM
  #17
sick9lt1's Avatar
Good Luck!
i do have varry little black smoke out the rear but the blow by and smoke out the oil fill tube is gone. i think that the car needs tuned it has all the stuff done and no tune, but i cant find anyone in tampa area that can tune it. i know the guy that did the dyno said that it was real lean but i dont see how lol he could not even give me a good tq reading.
Old Jun 5, 2009 | 10:56 AM
  #18
bw_hunter's Avatar
What Crane cam do you have?
Old Jun 5, 2009 | 11:21 AM
  #19
sick9lt1's Avatar
its hard to find not i did have i saved but dont know where it went but since the closed its hart but this is the one
PowerMax Hydraulic Roller Tappet Camshaft Lift: 479''/ 518'' Duration: 272°/286° RPM Range: 1500-5700
Old Jun 5, 2009 | 11:31 AM
  #20
bw_hunter's Avatar
that's similar to the LT4 hot cam specs. I'll be one of the aftermarket tuners could do a mail order tune for you. Have you ever heard of www.pcmforless.com?
  #21
sick9lt1's Avatar
bw hunter i fond the link and i bought this motor out of a 94 car and put it in my 93 maybe this is the problem, just read this about the cam i have in.
Crane Cams PowerMax 2033 Camshaft (1994-1997 LT1)
Crane Cams PowerMax 2033 Camshaft (1994-1997 LT1) [104227] $285.95 1.42975 Points Currently Valued at $1.43 FOR 94 AND LATER ALUMINUM HEAD EQUIPPED LT1 CAMAROS, FIREBIRDS AND CORVETTES. WORKS IN STOCK AND MILD MODIFIED ENGINES. BOOSTS MID AND TOP END WITHOUT LOW END LOSS. USE 10758-16 1.6 RATIO ROCKER ARMS FOR MORE POWER. NOT FOR USE W/STOCK SPRINGS. FOR MASS AIR F.I. ONLY. BASIC RPM 2000-6000 Year: 1994-1996 Corvette LT1, LT4 & LT5 1994-1997 Camaro & Firebird LT1 Tuesday 21 October, 2003.
look where it says for mass air fi only what dose that mean, i ont have the mass air like the .
Old Jun 5, 2009 | 11:33 AM
  #22
sick9lt1's Avatar
yea but i think thats like 5 or $600 rite
Old Jun 5, 2009 | 11:36 AM
  #23
bw_hunter's Avatar
No, no...$175 + shipping. You can even get Brian to tune a computer for you, ship it to you and then you send him back the core. That way you can even drive the car when he's doing the tuning and you're waiting for the mail....
Old Jun 5, 2009 | 11:43 AM
  #24
sick9lt1's Avatar
2 things who is brian and how do i contact him, and my fpr has 2 nipples out of it only the one on the bottom has a hose on it are they both in need of a hos or just the one
Old Jun 5, 2009 | 11:58 AM
  #25
bw_hunter's Avatar
Brian is the owner/tuner at www.pcmforless.com . Go to the website and you'll see all the info you need. He'll probably direct you to Alvin since yours is a 93 and has a removable chip...
My FPR only has one vacuum line connection point. It looks just like this one:
http://shbox.com/1/fp_reg.jpg .
You may have an adjustable FPR. Are you sure one of those nipples isn't a screw?
Old Jun 6, 2009 | 01:07 PM
  #26
sick9lt1's Avatar
update i did a fuel pressure test car holds it and wot 42 psi and around 39-40 just driving. got home turned off the car and it held at 40 ps1 for 20 mins so fuel system is fine?
Old Jun 6, 2009 | 01:59 PM
  #27
sick9lt1's Avatar
something i did not ask is that by the car running rich or lean could that be getting gas where it should not be. and maybe wash out the cylinders and cause blow by. and i still cant get to the bottom of the miss it dont do it all the time so i can only think that wot it is spiting oil all over things and then gets the miss. but cant see where the oil is comming form.
Old Jun 6, 2009 | 05:02 PM
  #28
bw_hunter's Avatar
Seems to be ok....
Old Jun 6, 2009 | 05:09 PM
  #29
bw_hunter's Avatar
I don't see how that's possible. If the injectors were to fire at the wrong time you'd just have fuel hitting closed valves...which is what you already have with the batch fire system on the 93's. Unless your injectors are way bigger than stock and/or your O2 sensors are shot, you're dumping the right amount of fuel at a close enough time to run right.
An intermittant miss is hard to diagnose and is a symptom of a bad optispark,,,along with other things. Try to fix the oil leak, test and/or repalce the O2 sensors and then we'll help you diagnose the remaining issues.
Good luck!
Old Jun 6, 2009 | 06:53 PM
  #30
sick9lt1's Avatar
Good luck!
ok man tyhanks i will do that. an i will get back to you all soon thanks for all the help. i thing the o2s are bad they have been soaked with oil to many times now. and for the lt headers he had to make wires for the o2s and ihave found loose bolts and thing like that alot. the guy that put in the motor sucks.
