Bad miss after washing
Old Sep 25, 2010 | 11:32 AM
1993Z's Avatar
I picked up a 93 Z28 a couple days ago for something to tinker with. It ran decent and had a hesitation off the bottom but after I washed the car and washed some oil off the engine, it was missing so bad it would hardly run. After I let it sit over night, it is only missing on one cylinder now. After reading on this site I suspect the opti but im not sure how to tell. Im hoping what ever it is will dry out and start working for now. Another problem is the guy I got the car from said the engine was from a 98 vette. I can see where they pulled the motor and it rubbed the cowl but I believe it is the original engine. Is there an easy way to tell if it is from a 98 or its the original 93 engine? I dont want to get the wrong opti when I change it.
Thanks in advance!
Shawn
Old Sep 25, 2010 | 12:16 PM
94CamaroZ28/SSClone's Avatar
You messed up your opti!!!! This is why your missing!!
Old Sep 25, 2010 | 12:17 PM
n2ceptor's Avatar
98 would be a LSx engine.... 93-97 is LT1.... Do you have a MAF sensor???? And if you have an OPTI, then it probably got water logged... Just needs to dry out..
Old Sep 25, 2010 | 01:10 PM
1993Z's Avatar
There is no MAF. I didnt really think the engine had been changed. Will the opti dry out and be ok? Should I change the system to the MSD vented type or just not get this one wet?
Thanks!
Old Sep 25, 2010 | 03:24 PM
moparman's Avatar
Give it a couple of days to dry, then see if it starts and runs OK.
Old Sep 25, 2010 | 03:41 PM
I had the same problem, well I overflow my radiator and it got the opti wet. I let it dry out for I think three days and I was lucky I did not need to change it out till later.
Old Sep 25, 2010 | 05:21 PM
1993Z's Avatar
Thanks everyone! I have had it running several times and it still has a miss on one cylinder. If it doesnt clear up in a few days I will tear it apart. Where is the cheapest place to get the parts or should I change to the MSD with the vent?
Old Sep 25, 2010 | 05:47 PM
NEVER EVER! Get the MDS Opti, those are a POS! I bought one for cheap off Craigslist new and it only last me half a day. Everyone on here knows that MSD Optis are no good. Its always better to buy a stock GM Opti.
Old Sep 25, 2010 | 06:29 PM
moparman's Avatar
Have you scanned it for codes?
Old Sep 25, 2010 | 10:19 PM
1993Z's Avatar
I havent scanned it because I dont have anything to scan it with. I would like to get something to run off my laptop but I dont know anything what to get. I would like to get something that will work on OBDII as well. I am open for suggestions because I need to get something.
Old Sep 26, 2010 | 09:03 AM
moparman's Avatar
Since you have a '93, you can jumper the pins in the diagnostic port.
http://shbox.com/1/dlc2.jpg
Old Sep 26, 2010 | 03:24 PM
1993Z's Avatar
Ok I jumped the OBDI port and got codes 26 and 32. I looked them up here http://shbox.com/1/Dtcs.htm and they are egr codes. Will this make the car miss? It is hard to start and idles fine but misses and backfires under acceleration.
markzzzz
May 8, 2015 09:21 AM
rideordie
May 3, 2015 12:53 AM
captcorvette
Mar 7, 2015 12:37 PM
DetroitZ28
Feb 13, 2015 07:33 AM
