Bad lifters?
Old Jul 9, 2003 | 12:00 PM
OffspringZ28's Avatar
Bad lifters?
How do you know when these are bad? doing a cam swap soon and wondering if they are necessary? car has 100k with regular oil change (except one change went 4k, not 3k). Where can i buy OEM replacements. Only have an XE 224/230 so i dont need crazy lifters like the 306 needs. About how much are they?
Old Jul 9, 2003 | 12:21 PM
WheelmanZ28's Avatar
Re: Bad lifters?
When I did my cam swap, my engine had 75K miles on it. Shortly after the install, some of the lifters went bad. I highly suggest that u replace ur Lifters since u are 100K miles. I wouldn't waste ur money on OEM replacement lifters. U can get a nice set of Comp Cam Pro Magnum Lifters for only $10 more than stock.
I ordered my Lifters from www.cmotorsports.com With Overnight shipping the bill was only $233.22. Not too bad IMO.
Old Jul 9, 2003 | 12:26 PM
ONELOUDKAR's Avatar
for sure replace the lifters... might cost you more than you want to spend but will prolly save you time w/o having to go in and re-do them later when they do go bad. good luck
Old Jul 9, 2003 | 12:35 PM
what about the lifters at Tbyrne.com theyre only 180.
Old Jul 9, 2003 | 01:38 PM
ONELOUDKAR's Avatar
you can do that or go to THUNDERRACING.COM and check out what they have
Old Jul 9, 2003 | 09:42 PM
The ones for 180 are only OEM replacement lifters. Like I said, spend the extra $10 or $20 and get the Comp "R" Lifters, also known as the "Pro Magnums"
Old Jul 9, 2003 | 11:46 PM
didnt know the 180 ones were OEM. thanks for the heads up man.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KamikaZ28
May 28, 2015 12:45 AM
