Bad Injector?
Bad Injector?
I'm pretty sure I have a bad injector how can I test them to see whats good and whats not?
P.S. What is the stock flow rate? Thanks
Assuming you think it's dead, you could swap it with another cylinder and see if the problem goes with the injector. If you think it is leaking, you could lift the fuel rails and the injectors up so you could see the nozzle. Have someone turn the key to on to power the fuel pump and see if any drip.
The stock flow rate is 24Lbs.
Well I'm thinking injector due to a gas smell and the horrible mileage I get (130 miles per tank) The fuel pressure was at 40psi so I don't think its the pump, only one o2 was running a little lean (changing soon) and I already changed the fuel filter and none of the lines are leaking or anything. What else could it be besides injector(s)?
How's the car running?? Is it hesitating, rough idle? The fuel smell could be something as simple as the vapor cannister. Have you checked for vac. leaks or exhaust leaks? Have you pulled one of your plugs and checked to see if they look rich? Could be numerous things.
Just did plugs, one did look bad when I took it out. Car runs great just has horrible mileage, no exhaust leaks and I don't notice anything under the hood making any sounds that aren't normal.
Originally posted by Kataklysm
Any other way to check to see if ones leaking besides how "slopokrodrigez" said? Can always do more then one to double check.
