Bad idel on first start after cold night
Old Nov 5, 2007 | 02:16 PM
93transam1234's Avatar
So if it gets cold outside at night in the mornning when i start the car runs rough for about a minute.
This only happens if it gets like under 40 Deg out side.
Old Nov 5, 2007 | 03:47 PM
Might be a problem with the coolant temp sensor in the water pump housing. If it isn't telling the PCM the temp is below 40*F, the PCM will not richen the mixture enough for a cold start.
Old Nov 5, 2007 | 05:47 PM
what will unpluging it do?
What else does that sensor control?
Could it have anything to do with a high rpm stumble?
Old Nov 6, 2007 | 11:28 AM
If you unplug it, it will tell the PCM the coolant temp is 40* below 0. The PCM will know the sensor is missing and set a code. How the engine would run at that point is anybody's guess. The coolant temp controls cold start A/F ratio, low temperature engine idle, tells the PCM when to go into closed loop, and affects the power enrichment mode target A/F ratio.
Old Nov 6, 2007 | 11:32 AM
Vicious95Z28's Avatar
I have the opposite problem, when it gets cold mine wants to run pig rich on the 1st start.
Old Nov 6, 2007 | 02:54 PM
Injuneer
power enrichment mode target A/F ratio, if that is f'ed up would/could it cause a high rpm miss-kinda like hitting a limiter?
Can you tell me what the difrence will be in PEM with it unpluged? Like less or more fuel?
Old Nov 7, 2007 | 11:03 AM
This one never got an answer, ttt
Old Nov 7, 2007 | 01:19 PM
Its hard enough to figure out how the engine will run when all the sensors are plugged in. You're asking me to decipher the GM hard-coded logic for defaults on loss of inputs, and I honestly have no way to do that.
Old Nov 7, 2007 | 01:32 PM
buzz12586's Avatar
Yea mine does the same thing. Having no cats makes it 10 times worse as well.
Old Nov 8, 2007 | 06:46 AM
you are now only 99% as smart as i thought you where
Fatdog2
Feb 13, 2015 08:19 PM
Jan 23, 2015 01:13 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
