Bad ICM maybe?
Bad ICM maybe?
My ignition control module is makeing a loud ticking noise, no its not my rockers, but is this a sign that my module is on its was out???
I do have a flat spot when i accelerate from 2000 to 3000 rpms...
Just wanted your thoughts on this, Thanks
I know the ICM is nothing more than a high speed switch. As for it ticking..I'm at a loss there. Coil maybe arching near there. My ICM did fine cold, then when it heated up, it went down the drain. It eventually failed.
