Bad high RPM miss, more info inside
Hey guys
Since May my car has had a high RPM miss. It feels like it's falling on its face at around 5600-5700 RPMs, and stays that way until it shifts. It barely wants to make it into overdrive because it struggles to get to the 3-4 shift point at WOT.
I checked fuel pressure, it holds 46psi through the gears.
Plugs and wires are fairly new, no arcing, no burnt wires.
At first I thought the transmission was slipping, because it almost feels like it's hitting the rev limiter..
Checked the coil wire which is also fairly new, and that looks fine.
This started after my electric water pump install (and more specifically, started RIGHT after I put on my Weld wheels with 275/50/15 Nittos) for some reason, so I'm assuming it's the optispark. I have a brand new GM replacement unit right here, so I will install it along with a new coil within the next few days, and I will update this thread for those who suffer from the same problems.
Feel free to post any comments.
Re: Bad high RPM miss, more info inside
Sure sounds like the opti. Its hard to diagnose just from a message board but the water pump swap screams opti to me. Did you get coolant all over the opti or otherwise disturb it in any way?
Make sure the wiring harness plug is securely snapped into the opti.
The recent waterpump install definetly makes me want to say opti but I wouldnt go rushing into it. Check out cheaper little things first. You might want to get a scan tool to help you narrow down your problem.
I want to order the www.obd-2.com scan tool, but they're closed until the 12th. Opti is sitting on my desk so I may as well install it.
If the opti was bad, would it show anything on a logged run?
I had the same problem a while back, new 02's, wires, plugs, opti, coil, and also had good fuel pressure... I was out of ideas.
So I went to auto zone and purchased a $25.00 set of plug wires to see if it would make a difference and it was fixed.
Just a suggestion, but $25.00 cured my problem
Alright, this is strange. I capped up the cutout, and it pulls 99% perfect to redline in every gear. Sometimes it may not pull as hard around ~5700 RPM's, but it's nothing noteworthy.
Gonna go to the track tomorrow. I'll make 2 runs on motor, and however many runs I can get in on a 100 shot.
I know, it's not the smartest thing to do to spray it right now, but I just "tested" it "extensively"
and it runs awesome.
If it blows, I'll fix it :P
and it runs awesome.If it blows, I'll fix it :P
Cutout might be causing some false knock. Have you installed an LT4 knock module yet?
Welp, the car is still doing it intermittently. I ordered software from www.obd-2.com w/2nd day shipping, so I'll post a few logged runs once I get it.
Deadbolt24
Jan 19, 2015 01:29 PM
squarehead
Nov 21, 2014 08:02 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
