bad gas mileage ???
Old Oct 11, 2004 | 06:20 PM
  #31
Silver's Avatar
Re: bad gas mileage ???
If you have LT1 Edit, some guys lockup early and add (or is it take away?) timing. Check out some of Christian Millard's thoughts on the matter. He did a whole test and all LOL...
You could set the shifts sooner and lockup sooner. I tell you what, driving habit can drastically affect your mpg. I'm not exagerating... it can make a world of difference.
Old Oct 11, 2004 | 07:38 PM
  #32
RedRyder518's Avatar
I don't really get it either. This past summer before my tuneup, I would get around 140 miles a tank in the city and after doing a complete tune-up, including plugs, wires, O2's, and my PCV valve, I still only get around 160 a tank. What else could it seriously be? I have no performance or miss issues and it idles smooth. Would a new coil help?
Old Oct 11, 2004 | 11:49 PM
  #33
camaro325's Avatar
well, yesterday I read my emissions on the dyno at my job and the hydro carbons was at like 14 and one other thing was low. one of the mechanics said it looks like a misfire..... so I bought 8 acdelco plugs(non platinum) and I bought a new fuel filter, hopefully this will help out, the pld plugs hade built up a littlebridging on the prongs and carbon deposits...however there was one that was terrible, it had alot of carbon and was fouled, the reason I think this happened is because my car ran with that wire off for like 10- 15 min...so I think that in that time period the plug got ruined.....
next weekend I think I'll do wires and o2's
ohh yes, and if there is some sort of special tool they use to change our plugs then please let me know, cause I thionk it's rediculous that it took me about 3 hours alone to do the right side....It had to be the most hardest and annoying thing that I've ever done.
scyzoryk, i live in middle village right by juniper valley park
Old Oct 11, 2004 | 11:56 PM
  #34
'94 Bad A Z28's Avatar
Originally Posted by sabre81
And i have a very heavy foot well i make sure my car is fully tuned up. and i tune my own pcm so i think that helps. one of my "secrets" is that i drive on roads that dont make me stop and go tooo much. Also i programmed my TC to luckup at 49, so i try to drive on roads that allow me to cruse at around 50 all the time so im in 4th gear, with tc locked, therefore im getting the best gas mileage. But basically i always have my car in tip top shape with new o2's, plugs, wires, pcv valve, fuel filter, and i also change my oil every 2000 miles. Right now car has 135000 miles and runs perfect
My converter locks up at 46mph and I don't get that kinda milage.
Old Oct 12, 2004 | 06:22 AM
  #35
jonota's Avatar
Originally Posted by ShawnMacAnanny
it is due to my Jet 2 module. They are really cool. The module looks at engine temps, rpm, knock, stuff like that, then safely maxes out the timing advance, the optimun A/F and other stuff like that. Plu its an electronic shift kit
Who told you all of that? I've looked at a Jet stage 2 program and it had almost nothing done to a/f ratios.... and as far as I know, no program out there can change the lt1's flash programming on the fly....
Jonota
ps I'm getting upper 16's, exhaust manifold->y pipe leak on drivers side right in front of the O2, previously getting aroudn 21 in town, 27 on the highway, M29 w/3.23
Old Oct 12, 2004 | 01:39 PM
  #36
Z28SORR's Avatar
Unfortunately, (not) I already have the 6 speed. And I've already taken into account my driving habits. This engine just plane runs rich. When I pulled the plugs they were all normal and the same, except for the carbon. If this were on my carb'ed engine I'd be rejetting it. This is on a car that is vertually stock, doesn't even have headers yet. And runs perfectly, no codes ,no lights, no miss or hesitation. I just find it hard to beleave that this car should ever get 13mpg. Of course it does weigh almost 4000lb. so maybe I'm just not being realistic.
Old Oct 12, 2004 | 02:26 PM
  #37
jonota's Avatar
offhandedly here, does your car have a loud popping noise on decelleration?
Jonota
Old Oct 12, 2004 | 03:14 PM
  #38
Z28SORR's Avatar
I have the TOLT without the "Cone". So yes, it growls quite nicely on decel. I know there you're headed here, but I don't think it's off nominal. Not that it couldn't be, but I have a lot of experiance driving cars with different types of exhaust, and I don't find this one to be unusual.
Old Oct 12, 2004 | 05:47 PM
  #39
jonota's Avatar
well I might be headed somewhere a little different, as I had a problem that was making my mileage HORRIBLE that NOONE could diagnose until I stumbled upon it one day. have you hooked it up to a scanner to see what your fuel trims are? if you happen to be saying you're running super lean, I have a test for you.
On my car, the check valves for the AIR system failed, causing the manifolds to suck in air at all times through the intake system. This caused a loud popping sound on deceleration. After removing the AIR system, and plugging all it's holes, the popping noise went away, and my fuel mileage went back up. Now I have a manifold leak that's dropping the mileage back down...
Just a thought
Jonota
Old Oct 13, 2004 | 09:37 AM
  #40
Z28SORR's Avatar
No scan yet. I'll get there eventually. Thanks for the info. I don't think this is the problem but it's definitely worth checking.
Old Oct 14, 2004 | 12:45 AM
  #41
camaro325's Avatar
I think it may be my opti, cause I changed my plugs and fuel filter, and didn't fix, and from the high number of hydro carbons it's putting out it looks like a dead miss, plus every once in a while the car will studder when I push the gas....I will know definate tomorrow though
Old Oct 14, 2004 | 02:39 AM
  #42
ShawnMacAnanny's Avatar
Jonota
No one person has told me that. I've read a few things and that's just my impression of what the Jet 2 module does. What does it do then if not that?
Old Oct 14, 2004 | 04:46 AM
  #43
jonota's Avatar
First off, that's what all of the "performance module" companies say, or something very similar. For our cars, you can easily MONITOR all of those things using a scanner, which there are several out there. HOWEVER, changing the programming on the fly is something that hasn't been done yet (to my knowledge). Most of the performance module change some part in the programming to attempt to get you more power. In our cars, a quick and easy way to do this is to modify the spark advance tables, and the WOT target A/F tables (these are not their names in the program). Having looked at a Jet stage 2 performance module's attempt at changing the lt1's programming, I can tell you it did very little. As do MOST of the performance modules out there. I could look it up specifically and tell you, but off the top of my head I would say no more than 3 cells of the spark advance table were changed, and if I recall, NOTHING on the a/f ratio tables.
Secondly, I ask you this: have you done any testing that conclusively shows ANY benefit. Often times, we get a little excited after doing a mod to our cars, and we "think" we feel a difference. I am just as to susceptible to this. I used to have a HPP3, and swore up and down it made the car faster, but POWER wise, it did little to nothing. Now most of the companies DO make changes to the transmission programming on an automatic, which can help your cars quickness in shifting, and change your shift points. This also leads to the reports of our weak 4l60e's detonating a bit early.
So, the basic answer to the question your really asking is no, it didn't do much for you. Most people who have some experience accessing the lt1's computer will tell you that most of the program modules out there are good for recalibrating your speedo, and changing your fan on/off temps, and that's about it. Sadly, this isn't because they aren't ABLE to significantly change your engines power (I believe on a pure stock engine Ion or MadZ28 gaurantees 14 hp??), it is just that they don't bother to do so.
Jonota
Old Oct 14, 2004 | 08:35 AM
  #44
I didn't put it on, it was on when i bought the car. My car does shift at 6,000rpm in performance mode and regular mode, but performance mode is much harder. I could take it off an test it that way but im too lazy. I did order a Jet SCU2000 which is going to remove my speed limiter, but i could have gotten a tune fo the $58 i spent on that.
Old Oct 14, 2004 | 04:26 PM
  #45
jonota's Avatar
Or you could have bought a cable and done it yourself. Lots of people out there to help, and if you don't trust that, there's lots of people out there who will do the tune for you...
Jonota
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kksi
Mar 21, 2015 09:03 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
