Bad gas or bad plugs????
Guys hope you can help...Was at a stop light and started to pull off when I did the car started stalling/bogging out, I had to "pop" the clutch to keep it going. Got to the next stop light and it did the same thing. Started drving fine after that except that you could feel a slight skip/jerk as I was driving it. Now all this started right after I stopped and got some gas. So could it be the gas or the plugs cause car has 90,000 miles on it.
Re: Bad gas or bad plugs????
If a plug or wire was grounding out it would have a similar effect to what you're saying.. If they have 90k on em I would replace those anyways with a set of taylors and some autolite 106's.. Bad gas would pull a bunch timing and the thing would probably ping and be dog all the time..
Deadbolt24
Jan 19, 2015 01:29 PM
