Bad emergency brake
Old Jul 19, 2004 | 09:41 PM
eagleknight97's Avatar
Question Bad emergency brake
Whenever I pull on my E Brake, not much happens. I dont use it that often, seeing how its an Automatic car, however, i would like to have my e brake in good working order. How can I do this?
Old Jul 19, 2004 | 09:44 PM
speed_demon24's Avatar
Re: Bad emergency brake
Thats exactly how mine is, it works, but its not nearly as stronge as I would like it to be.
Old Jul 20, 2004 | 04:41 PM
Austin96Formula's Avatar
Have you ever done work on the rear brakes? There are some springs that go on the e-brake parts on the brakes. I was missing a single spring and my e-brake would not work for anything. Spring was like a $5 or so part.
Old Jul 20, 2004 | 04:58 PM
961le's Avatar
when i changed my rear pads my e-brake would not hold any. you probobly need to do the free travel adjustment. the hardest part is removing the springs. after that piece of cake.the other hardest part is putting the springs back on.
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
15
Mar 13, 2015 12:30 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
