Bad Alternator Question
Old Jul 19, 2004 | 01:09 AM
Ace_437's Avatar
So I think my alternator is going out, not the whole thing, just the bearings in the pulley. Can I just swap them out, or do I need to change the whole thing?
Old Jul 19, 2004 | 05:20 AM
slopokrodrigez's Avatar
Re: Bad Alternator Question
It can't hurt to try but more often than not, it won't work. If you plan on replacing it, then you won't get dissappointed when the bearing thing doesn't work. BTW, buy only OEM and not one from Autozone or Advance (lifetime warranty doesn't mean crap if the car never runs).
If you have a large stereo or amp, you may want to step up the current above 140.
Old Jul 19, 2004 | 07:36 AM
bdc95ta's Avatar
slopok where could he get an OEM alternator above 140amps? What's a good brand to get if he needs more and can't go oem?
Old Jul 19, 2004 | 07:25 PM
Above 140, the only good supplier I know of is Powermaster. But they are pricey. Hey but I'm to poor to buy cheap.
Old Jul 20, 2004 | 01:09 AM
Ace_437's Avatar
I don't need anything above the stock alternator. I still have the Bose cassette deck.
Old Jul 20, 2004 | 01:30 AM
bunker's Avatar
You can get one from GM its only about $40 more, just ask for the 94 B4C police package alternator for the Camaro.
The 9C1 caprice one works too but it'll only attach by 2 bolts cuz the third bolt hole isn't there & the alternator back section has to be flipped 90* for it to become the same, the 9C1 ones have a smaller diameter pulley also which helps with charging even at low RPMs since Impalas/Caprice 9c1s idle at 550rpm & have their cherries on at the same time, all radios, big dome light etc... you get the picture LOL.
BTW I like that metal sludge chick of the month there, mmmm... I like chicks like that in particular, its the look! Bah noone cares lol just thought I'd mention it LOL.
Old Jul 20, 2004 | 01:39 AM
bdc95ta's Avatar
how much are those powermasters roughly? probably not worth the money but just curious.
-b
Ace_437's Avatar
I got a quote of $212 from my local dealership today. I called one local place, but all they had was remanufactured alts. I might have to give Jason or Dal a call, though I'd like to get it done tommorow. Anyone have any experience with Napa and that sort of place?
Old Jul 20, 2004 | 05:17 AM
The powermaster 200 AMP are around $329.00
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
Hurin
Dec 13, 2014 07:38 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
