Backup (reverse) lights come on when
Old Nov 27, 2003 | 02:29 PM
FRDnemesis's Avatar
The other night I walked out to my car to leave work, started the car, and as soon as I turned the headlight switch on the reverse lights turned on.
If I start the car (without turning the light switch on) and put it in reverse, the lights function as they are supposed to. But once I turn the headlight switch on (even just parking lights) the backup lights come on and stay on until you turn the headlight switch back off.
At first I thought backup switch! But as long as I leave the headlight switch alone they come on when I put it in reverse and go off when I take it out of reverse. So I would assume the switch is working properly.
Does anyone know if the headlight switch is tied into the backup lights circuit?
I appreciate any help I can get.
Thanks,
Jeff
Old Dec 19, 2003 | 02:25 PM
FRDnemesis's Avatar
Well, I found the culprit. The power wire to the tail light was pinched together with the power wire to the backup light
(drivers side).
That explains why the backup lights illuminated when I turned the headlight switch to either of the powered positions. It also explains why I didnt get a fuse to pop.
The strange thing is, I havent messed with those tail lights since I did the conversion to the new style over a year ago.
Jeff
Old Dec 19, 2003 | 02:30 PM
bunker's Avatar
have u been bad this year ? Santa pinched your wires man!!!
Old Jan 8, 2004 | 11:23 PM
wildcard's Avatar
Wink
Damn Jeff, great job finding the culprit, and you did it all by yourself
Ben
Old Jan 9, 2004 | 11:18 AM
FRDnemesis's Avatar
Ben
Well, I've got two words for you Sergeant !
"Kiss @ss"
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
kizz
Aug 28, 2002 09:39 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
