backpressure question
Old Sep 20, 2005 | 08:20 PM
  #16
engineermike's Avatar
Re: backpressure question
I've seen cars pick up 100 rwhp by removing the seemingly good exhaust system they have.
Some LS1's don't gain any hp by removing the exhaust. This is what spawned the whole reverse-split duration cam craze for the LS1 folks. If the cylinder head is over-exhausted, then it can benefit from having more intake than exhaust duration.
That's neither here nor there, though. . . I've heard of certain engines losing power due to lack of backpressure, but in every case, it's been an extreme application with too much overlap. I'm talking about Hemi's with 400+ cfm heads and cams in the 280@.050 range. There's so much overlap that the exhaust pulls the air/fuel right through the chamber into the exhaust. Backpressure helps, but reducing overlap helps more.
That said. . . running open headers with an LT1 causes some other problems, namely O2 sensor readings. The O2 sensors are too close to the collector, so fresh air eddy's and pulses into them, thus giving them a false lean reading. The computer will quickly start pouring fuel in. After about 3 miles, the car will barely run. I know this from experience. All you really need to fix this problem is about 18" of pipe extending off the collector.
Mike
Old Sep 20, 2005 | 08:24 PM
  #17
93camaroLT1's Avatar
Mike
I wasnt planning on running O2s...
Old Sep 20, 2005 | 08:26 PM
  #18
Originally Posted by mrr23
collector extensions is what it's called that you are wanting to do. this helps to promote more midrange power. the pipe will be the same size as your collector diameter. how long will be a guessing game. make a long piece. spray a paint line on them. make a run. look for the point where it burned the paint off. cut there.
nope, not trying to create more midrange power, the cam I am using will have more midrange than I need. I'm only really looking at MAX hp, I just want the ideal amount of piping were the car doesn't lose any hp top end due to too much velocity or due to backpressure. Backpressure doesn't sound to be a issue, being that there will be none with open headers, but do you lose HP due to there being too much velocity with open headers?
Old Sep 20, 2005 | 08:29 PM
  #19
Old wive's tale.
What, exactly, does the exhaust temperature, conductivity of exhaust tubing, and paint decomposition temperature have to do with the power curve???
Old Sep 20, 2005 | 08:31 PM
  #20
Run open headers with no extension, then.
Old Sep 20, 2005 | 08:34 PM
  #21
Would I lose any top end HP running open headers due to too much velocity with no extension?
Old Sep 20, 2005 | 08:35 PM
  #22
keep in mind, although the car has nitrous, it is ussually running N/A with a mild cam and some head work
  #23
Nope.
Old Sep 20, 2005 | 08:40 PM
  #24
well that answers that question then.
Old Sep 20, 2005 | 09:24 PM
  #25
GreenZLT1's Avatar
My car ran like crap with open headers. No power anywhere. Put on the y-pipe and catback, and now it runs like a mother....
Rob
Old Sep 20, 2005 | 09:27 PM
  #26
Got dyno results?
Where are your O2 sensors?
Old Sep 21, 2005 | 01:35 AM
  #27
There are countless numbers of people on here that say that their cars run terrible on open headers, which was the reason for this post. But looking at everything I suspect that a lot of these people are attempting to run their 02s with open headers which would in terms cause their cars to run like crap. (that and possibly something with tuning, or lack of it.)
Old Sep 21, 2005 | 01:45 AM
  #28
only 2 things I can really think of towards why a car would run bad on open headers, but good with a exhaust.
1. Trying to run the O2s in the collectors with open headers causing false readings and therefore the car runs poorly.
2. Their actually is a lack of enough backpressure causing a performance loss, meaning that you do need some kind of backpressure on LT1's N/A without lots of compression. (I do question this though.. I attempted to run my civic si which is a 1.6 liter with 10:1 compression without a exhaust and flooring it on the highway at 60 the car litterally would not move, proving that backpressure (or velocity, whatever you want to call it) is needed in some applications. I just don't know if that is the case with a LT1 being that it has over three times the displacement of the honda.)
Old Sep 21, 2005 | 01:48 AM
  #29
1racerdude's Avatar
stock cars/ race cars are also running much, much, much higher compression than I am and nitro-methane. I am only running 10.7:1 compression, i'm sure open headers will be awesome for power with the nitrous, but I question if the car will make as it could N/A with open headers, but then again I don't know since I havent experimented, which is why I ask.
What's compression got to do with open header's?
Pro stock don't run nitro.
If ya aren't running 02's just get it tuned.
Old Sep 21, 2005 | 08:51 AM
  #30
I run a Borla XR-1 on each collector. The local track required that all cars have mufflers, and then the next year they added the requirement that the exhaust dumps at least past the rear edge of the door. I added 3" pipes with turndowns, and could see no difference in rwHP with and without the pipes/turndowns. And that's based on running the dyno pulls (NA and N2O) one right after the other.
http://cjcfo.fbody.com/members/injun.../DCP03675a.jpg
I would be careful with running a pipe the same diameter as the collector, with no muffler. In effect, your are extending the collector, and that might not be good. It sometimes helps to "decouple" the collector from the rest of the exhaust with a "chamber".
