Backfiring through intake
Old Mar 25, 2006 | 04:19 AM
lt11997's Avatar
I just got done installing the hotcam kit and when I started it up it backfired through the intake so I shut it off. I tried starting it again and it won't start.
I am pretty sure a couple of my rockers are adjusted too tight because on a couple of them I adjusted and then felt the pushrod loose so I went and adjusted the again ( which I now realize isn't right).
Is there anything else that would cause backfiring through the intake besides having the rockers too tight?
Old Mar 25, 2006 | 05:01 AM
MeanGreen97Z's Avatar
Re: Backfiring through intake
Timing might be off....
Old Mar 25, 2006 | 05:06 AM
lt11997's Avatar
When I put the timing chain on the cam gear was at 6 and (with the dowel pin in the 3 O'clock position) and the crank gear at 12.
Old Mar 25, 2006 | 05:17 AM
Well then the timing sounds fine. Go back and readjust the rockers. Did you follow the tech part of shoebox's website for adjustment of the rockers?
Old Mar 25, 2006 | 05:38 AM
Loadre's Avatar
Stick a battery charger on it then try to fire. When my battery gets weak it has done this a couple times. Still can't figure out why.
Old Mar 29, 2006 | 04:43 PM
lt11997's Avatar
Fixed my problem, I readjusted my rockers and it still backfired but through the exhaust. I then checked my plug wires and I had a couple mixed up.
The cam runs pretty good on the stock tune but I can tell there is definately more power left in it. I'm going drive it around a little bit and then look at my fuel trim and knock retard etc. with the Tech 2.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Chet1185
May 10, 2015 09:24 AM
Noenav
Apr 30, 2015 01:06 PM
Drtryder
Apr 22, 2015 04:17 PM
F(ast)-body
Feb 26, 2003 09:05 AM
